The curves that I import do not appear
I am trying to import curves as csv files and they are not visible in the interface. If I click "Reframe On" can´t see anything
Can you provide the CSV file you are trying to load?
(09-04-2020, 11:56 AM)Albert Wrote: Can you provide the CSV file you are trying to load?
Of course
Of course
well, I can´t
You should be able to compress the CSV file to a ZIP file and upload it.
(09-07-2020, 12:55 PM)Albert Wrote: You should be able to compress the CSV file to a ZIP file and upload it.
.zip   C1.zip (Size: 1.12 KB / Downloads: 669)
Hi will27,
Check if you have "Display curve" option checked and "Don't display object smaller than" unchecked. You can find these options in Tools->Options->Display. Screen in attachment. I had the same issue and when I adjust these option like this then it was working.
Piotr
(09-08-2020, 12:44 PM)Piotr K Wrote: Hi will27,
Piotr
That was the problem. Thank you so much
