Too many reference frames when importing step fil
how do I get rid of all reference frames when I import a step file?
RoboDK imports STEP files as one single object by default. You may have changed the default setting. You can revert this setting here:
  1. Select Tools-Options
  2. Select the CAD tab
  3. Set the Action when importing a STEP file to Load as one object
(02-12-2024, 08:37 AM)Albert Wrote: RoboDK imports STEP files as one single object by default. You may have changed the default setting. You can revert this setting here:
I found the setting and it worked!
Thank you!
