UF and UT number
Is there a way to change Fanuc's UFRAME (UF) and UTOOL (UT) numbers for Fanuc LS files output in RoboDK?
If your tool or frame has a number in the name, the post-processor will assume that it is already in the registry.
If you want to save the UF and UT values to the registry, you can use the post-processor editor
https://robodk.com/doc/en/Post-Processors.html#PPEditor
(08-03-2023, 08:09 AM)Alex Wrote: If your tool or frame has a number in the name, the post-processor will assume that it is already in the registry.
thanks
