04-14-2025, 02:12 PM
Dear all
I am using an OPC UA Server that is running in RoboDK to communicate with some client (in this case i'm using UaExpert for testing). I can connect to this server and can use the standart methods and variables (like getItem, getJoints, etc.) but I can't access the Station Parameters on my client. In the UaExpert i get an empty string instead of the Parameter defined in RoboDK as you can see in the images attached. What could be the issue here? I am using version v5.9.0
Best regards and thank you for your help
Tobias Banz
Tobias Banz
