UR Robots and Force Mode
Hello!
We would like to use the so-called 'force mode' (UR Robots). Can this mode be used in simulation? I suppose that we can't use this in the simulation, because I couldn't find anything on this topic.
Best Regards,
Mitja
This should be simple to implement in RoboDK. You should trigger the calls/threads to force_mode and end_force_mode. I recommend you to take a look at RobotiQ's post processor example. These algorithms will not be simulated though.
https://robodk.com/doc/en/Robots-Univers...DK-RobotiQ
You can customize your force mode in your post processor so that you can trigger a program call from RoboDK that will trigger a specific force mode.
