UR10 robot support
Hello
I have a few questions about the UR10 robot.
This robot has the control version: PolyScope 1.8.16941 (Feb 10 2015) Robot Controller. Is it possible to run the program from an .urp file?  The program from the .script file work fine but with urp file is problem.
Do the available post processors support older robot versions and newer ones (e-series)?
Will the end of support by the manufacturer of the UR10 robot version CB2 in 2022 affect the cooperation with robodk?  Will roboDk continue to support this robot version in new program versions?
Thanks.
Hi Lucjan,
What kind of issue are you facing?
As far as I know, it should work.
And no, the fact that UR stops supporting the CB2 version won't affect the cooperation with RoboDK.
We support pretty old controllers for other robot brands.
Hi Jeremy
Thanks for the reply.
So far the problem with running the .urp file has been solved.
Greetings
Lucjan
Did you do anything differently?
Do you know where the problem came from? If you do, please share for other users.
