A few really painful issue for me:
1) The software keeps forgetting license file information every time after restarting the program (not restarting the computer, just the program). So I would loose what I was working on because it won't let me save OR it won't let me input the license code. I had to restart the program, it will be Free (limited), then re-input the license code, and then redo all the work.
2) The program editor also have issue. After generating the program code showing up in the Program Editor, you can only excuse any one command once and it will not response to another command again. For example, go to Help -> About, and a dialog box shows up. And the do the same Help -> About, and nothing happens. And other command won't work either.
3) I was generating program for a KUKA robot. There should be multiple files generated, and only a *.src would show up. What ever was generated wasn't working for the robot.
4) Same thing after I replace the robot in simulation to a NACHi. The generated code looks different, but still it won't work for the robot either.
5) Is there live help available??
