Threads: 8
I would like to know if it is possible to use the SolveIK call to solve for a point/vector only (not force a fix xt/yt direction)? In some case (like a touch probe) it is only necessary to solve for a point/vector.
Is this already possible or do we have to do it by trial/error ?
Thanks,
Francois
227
Your request may have different answers depending on the mechanism being used. Specifying a point and a vector is a 5-DOF constrain and it would give you a unique solution for a 5-axis machine (which makes sense).
For example, for a 6-axis robot, a 5-DOF constrain (like specifying a point and a vector) would give you infinite solutions. Another example is that a a 6-DOF constrain (full position and orientation, also known as pose) on 7-axis can easily give you infinite solutions.
Another example would be for a 5-axis CNC: specifying a point and a vector constrain makes total sense as this is a 5-DOF constrain for a 5-axis machine. In RoboDK when you provide the pose to the SolveIK function, we only account for the position and the Z axis of the machine flange to perform the inverse kinematic calculations.
For your information, we have recently improved the solver of 5-axis CNC to prioritize the XYZ position of the machine tool flange and the Z vector of the same flange.
Threads: 8
this I already know how to do.
What I mean is what if the Pose that was computed by point_Zaxis_2_pose is not reachable by the robot (SolveIK can't find a solution).
It looks like you don't have a way to do that except by trial and error, use SolveIK with different pose (same point/normal but different xt/yt direction) until SolveIK worked, is that right?
Thanks,
Francois
227
Great then. We don't have another solution for now. Another option is to iterate over the pose by changing the rotation around the Z axis and calculate the inverse kinematics solution, for example, from 0 to +/- 180 deg around the Z axis by steps of 45 deg.
227
There is no other way for the time being but let us know if you have performance issues and we can take a better look to help you implement a custom solution.
