01-24-2024, 06:10 AM
When I use a touch screen monitor with robodk and I want to orbit/rotate the view around an object. At times it will not detect that the touch position is over an object to orbit around it. This will cause the view to be thrown off because of how sensitive the rotation is especially when I get closer to an object to view it.
From what I've noticed with a mouse, is that if you click the mouse over an object it will orbit the view around the point on the object that it was clicked on. If you do not have the mouse over the object then it will orbit in open space in the center of the view. Or orbit around the object that it found in the center.
I've also noticed that if i set the object's opacity to be below 50% then I cannot select it anymore nor does it affect the orbit. Is it possible to have it still be detected by the orbit but not be select-able?
