04-24-2019, 04:38 PM
Hello, is it possible to set the python environment to Virtual environment in the RoboDK?
Virtual Environment
04-25-2019, 10:38 AM
RoboDK automatically includes the RoboDK/Python folder as the python path (PYTHONPATH variable) when you launch a Python program from RoboDK. You can place any dependencies there.
If you want to create different environments it may be better to setup a separate projects (for example, using VSCode or PyCharm) and install the RoboDK API for Python on your preferred Python version: https://pypi.org/project/robodk/ The RoboDK API also works when you launch it externally (not using RoboDK). |
Users browsing this thread: |
1 Guest(s) |
