I'm trying to load a Fanuc LS program wich calls serveral programs/functions. However on all of them i get the same errors:
It should be noted that I only have acess to the backups and not the full program so Im thinking that there is some file that I would need to solve the problem.
P[1] in filename.LS looks like this:
Reading C:/Users/raz/Desktop/folder/folder/md/filename.LS...
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 56):
P[1]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 62):
P[2]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 68):
P[3]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 74):
P[4]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 80):
P[5]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 86):
P[6]{
Warning: Failed to find a valid solution for target using programmed configuration/turn flags (line 92):
P[7]{
Warning: Unknown UF 1. Rename a reference frame accordingly to establish a link with the station.
Warning: Unknown UT 2. Rename a reference frame accordingly to establish a link with the station.P[1] in filename.LS looks like this:
P[1]{
GP1:
UF : 1, UT : 2, CONFIG : 'N U T, 0, 0, 0',
X = 690.605 mm, Y = 548.212 mm, Z = 475.951 mm,
W = -1.953 deg, P = -15.912 deg, R = 10.607 deg
