Yaskawa Motoman cartesian only post error
This post starts with something like this:
/JOB
//NAME P1001
//POS
///NPOS 8845,0,0,0,0,0
///TOOL 0
///POSTYPE PULSE
///PULSE
C00000=-987,18260,-48264,-142788,62257,26291
///USER 3
///TOOL 0
///POSTYPE USER
///RECTAN
///RCONF 1,0,0,0,0,0,0,0
C00001=89.993,245.500,135.000,0.00,-0.00,-100.00
C00002=89.993,245.500,30.000,0.00,-0.00,-100.00
C00003=89.993,245.500,28.000,0.00,-0.00,-100.00
This is ok. Except that when the post start with PULSE in the program. The next part gives a 3190 error on the controller. Relative Job error as that is not compatible with the pulse start.
C08844=193.833,270.304,80.000,0.00,-0.00,-100.00
//INST
///DATE 2024/04/05 00:27
///COMM Generated using RoboDK
///ATTR SC,RW,RJ
////FRAME USER 3
///GROUP1 RB1
NOP
'Program generated by RoboDK v
'5.7.1 for Yaskawa GP25-12 on
I needs to look like this:
//INST
///ATTR SC,RW
///GROUP1 RB1
NOP
When the JBI file starts with pulse it is NOT a relative job. another sub program can do that, but not the file with the pulse start.
If you want to output all targets using Cartesian data instead of pulses you can change this setting:
  1. Select Tools-Options
  2. Select the Program tab
  3. Set Output for Joints movements: Cartesian data
  4. Set Output for Linear movements: Cartesian data
That fixed the problem, but not the bug. Thanks
Great, thank you for your feedback.
