01-28-2021, 02:20 AM
hello,
let's suppose i have a list of points on the curved surface. and i need to drill it vertically,
i want to use a target on the surface, but making targets manually is practically not good and takes a long time.
so in my view, the basic process is to make CSV file of the hole location x,y,z but to make the target perpendicular to the surface, I need W, R, P value of that point. is it possible to use teach on target function from python, then i could have select the surface as a guiding surface, and select the points. then the virtual target will be made on those points in perpendicular to the surface.
Thank you in advance,
