hyperMILL Setup
I would like to set up hyperMILL plug-in, but the below link on RboDK documentation seems not to have any files to install.
https://robodk.com/files/upload/hyperMIL...RoboDK.zip
Could you upload it here or on the documentation once it is ready?
Best Regards,
Hiroe Ota
We just added the missing file to our website. I also attached it here.
Let us know if you have any issues.
.zip   hyperMILL_AddIn_RoboDK.zip (Size: 241.67 KB / Downloads: 790)
Thank you for the file.
I noticed that hyperMILL has the version integrated with SOLIDWORKS.
Is RoboDK compatible with this type of product?
https://www.openmind-tech.com/en/cam/cad...olidworks/
Best Regards,
Hiroe Ota
The RoboDK plugin for hyperMill was mostly developed and tested with hyperCAD-s which is the default CAD software from Open Mind.
I would assume that our plugin won't work out of the box from the hyperCAD plugin for SolidWorks but should work if you go through hyperCAD-s.
We also have a plugin for SolidWorks but it does not include CAM features...
Could someone share a sample of the APT format generated by the hyperMill add-in to be loaded into RoboDK software?
The format may vary slightly depending on APT.
Thank you!
I attached a sample APT file generated by hyperMILL.
This example is very basic and part of a large project we worked on. Let us know if you need more samples or help. Contacting hyperMILL may help obtain a compatible plugin for your version. The DLL we provide is for a specific version of hyperMILL (the same one mentioned in our documentation).
@Phillip can help you by providing more examples if you need.
.apt   Robot-Machining-Test-hyperMill-RoboDK.apt (Size: 4.34 KB / Downloads: 684)
