issue with path projection using python and curve follow project
I've been trying to create a path and project it onto a surface but am running into issue when the curve is being projected. The surface is a hollow cylinder and I am trying to project half circles onto the inside of the cylinder, following the circular paths. When I do the projection it doesn't follow the correct curve and ends up making a completely different curve being followed that doesn't equate to the one I generated. I thought it was maybe because my circles were too large and were covering the surface but even after changing the diameter it did not help.
Can you give us a bit more information?
Screenshots, .rdk station with objects, and example script.
I have attached the station along with the script, and the simulation of what it does when it projects onto the part. I have paths for the part but they are not projected.
station
My colleague found the issue. Thank you!
