kuka krc2 connection
hello everyone,
i'am working on graduation project (KUKA KR210_2) ,Kuka KRC2 with software version 5.2
i want to control it using my laptop(robodk) but i didn't found an onboard ethernet so should i buy an ethernet card,we found these two network cards 00-116-626 and 00-133-342 we want to make which one is suitable for our robot?
or is there any other method to control it (i mean serial using profibus or devicenet)
thanks in advance
The controller is Windows based so you should be able to configure any Ethernet card. However, I recommend you to contact official KUKA support to make sure it works for your controller.
Also, you should still be able to program robots offline without setting up the driver by generating the programs from RoboDK (SRC files for KUKA controllers). You can transfer program files using a USB drive.
i know but my project is to communicate with the robot using my pc
do know is that possible to use the RJ-45 port in mfc board as network plug?
