setParam not effect via Python API
Information
In the current version of RoboDK the "setParam" commands didn´t take effect on any kind of items.
For example the following code not work.
from robolink import *
RDK = Robolink()      # Start the RoboDK API
# How to change the number of threads using by the RoboDK application:
item = RDK.ItemUserPick("Select an item")
item.setParam("Tree", "Expand")
pause(2)
item.setParam("Tree", "Collapse")
You have to pick an item like Frame, which have other items, like Targets defined under it.
The code works except the pause instruction. Pause is used for a Pause instruction in a program. Documentation here: https://robodk.com/doc/en/PythonAPI/robo...Item.Pause
You can use this instead:
import time
time.sleep(2)
Thanks Vineet.
In the case of command "Tree" seems that works.
I´m trying to open a robot options form using setParam.
I use the following code, but nothing happened.
item = RDK.ItemUserPick("Select a robot", ITEM_TYPE_ROBOT)
item.setParam("Form" , "open")
Make sure to update RoboDK to the latest version. This Form Open/Close option was added a few months ago.
(06-27-2021, 07:26 AM)Albert Wrote: Make sure to update RoboDK to the latest version. This Form Open/Close option was added a few months ago.
I´m using version 5.2.4 and Form Open still does not work, what I'm doing wrong?
"Close" seems to work, but "Open" don't do nothing!
