Trying to figure out what is a2 & a2 in "Build/modify mechanisms or robots" page when we configure "2 rotative axes" ?
"2 rotative axes" configuration. |
05-23-2022, 05:44 PM
The first A2 refer to the orientation of the FbHb frame while the second A2 refer to the translation distance between Fb and FbHb. Both are relative to the the X-axis vector.
05-28-2022, 08:19 PM
I have a weird robotic arm. I am not sure if it is industrial robot or collaborative robot.
I have the arm links designed and know which two links join and their rotations. Is there a way I can define a custom robot mechanism other than the one already provided? I am thinking along the lines of if you see in this video how the robot parts are separate and with "joint" command of Fusion 360 the pieces are put together. https://www.youtube.com/watch?v=4YTZ9FGB7jU&t=203s". Then the angles are varied to move the robot. I don't know a way in Fusion 360 to define start and end point of robotic arm and arm will path plan accordingly. I am still learning RoboDK. I believe RoboDK has the feature that you define start and end point and it can figure out the motion path. That is why i am inclined to explore more in RoboDK. Thank you for understanding and any direction. I can understand this video of pick and place "https://www.youtube.com/watch?v=FRnWPXQr1G8". For me to reach here, I need to first create the custom robot model mechanism and hence this request. |
Users browsing this thread: |
1 Guest(s) |
Powered by MyBB
