  • 1 Vote(s) - 5 Average
2D camera issues on Mac OS
I have few issues with Cam2D on Mac OS:
1. Camera can see objects just fine with 'Color' view type (attachment #1). But when I change view type to 'Depth' (attachment #2) it crops the view field (see attachment #3). Code is here https://github.com/GRusar/robodk-camera-issue
2. I set all Camera settings in python script. But it won't be applied until I open the settings in the GUI and click OK there.
3. So if I set param in the python script
RDK.Cam2D_SetParams("DOCKED", cam_item)
it won't be mapped to GUI at all. So I should manually check the control.
4. The settings won't be persisted if you close the camera with:
RDK.Cam2D_Close()
Any ideas?
Thanks in advance,
Yury.
We just fixed these issues when using 2D camera simulation on Mac. Can you try to download and install again?
Let me know if you still have issues.
Just downloaded new installer from the site. The release number is the same 5.9.0.25042 date: Jan 21, 2025.
(01-30-2025, 05:45 PM)yurykotlyarov Wrote: Just downloaded new installer from the site. The release number is the same 5.9.0.25042 date: Jan 21, 2025.
Still not works... Mac OS (Apple Silicon and Intel)
Can you try downloading again?
Our new releases can take up to 24h to propagate through our CDN.
still the same release #
It is still the same release. By the way, the release date doesn't even match the last one from What's new page
Maybe we should download from some special page instead of from https://robodk.com/download ?
Did you try reproducing the errors?
I was unable to reproduce the issues raised earlier with the latest version you can download from the download link I provided. Even if the build date is the same. This may not sound consistent for the Mac OS installer but it should be the latest version that fixes these issues.
(02-02-2025, 08:25 PM)Albert Wrote: Did you try reproducing the errors?
Yep, I can reproduce all issues
Today, I'm downloaded the installation file from https://robodk.com/download
deleted the previous installed version (via ~/RoboDK/RoboDK-Install-Repair-Uninstall.ini)
then install latest
md5 Install-RoboDK.dmg
MD5 (Install-RoboDK.dmg) = d79f737e23b6d986ab22055fc28706e6
OK, the download of the installer should be correct now.
Try to download again for Mac OS and you should see this:
MD5 (Install-RoboDK.dmg) = 9bd2316c4fc1f510778ecf7f88e2adc6
