3D printing
Hi Guys.
I am trying to perform my 3d printing project. I converted my 3D model to G-code using Ultimaker Cura slicer. Then, I uploaded it in RoboDK and created a machining project. But I cannot move uploaded NC file into the working zone where the robot is located. I tried all the features, read all your documentation, but still cannot solve it. What am I doing wrong? I attached my working station to make it clear. Please, zoom out enough to see the uploaded model, it is far from the robot. Thank you.
.rdk   New Station (2).rdk (Size: 1.59 MB / Downloads: 1,000)
Did you try Slic3r?
https://slic3r.org/
You should move the machine coordinate system to be near your part in your slicer software. I believe you've defined your machine with a 10 x 10 meter printable area and the part is centered at XYZ = [5000, 5000, 0] mm. If you move the coordinate system of your NC/Gcode file to [-5000, -5000, 0] mm you can see that the part origin matches your table coordinate system.
.rdk   3D-Printing-Relocate.rdk (Size: 4.38 MB / Downloads: 1,036)
