Add Borunte BRTIRPZ2080A into the library
Do you have the POS for four axes?
.robot   BRTIRPZ2080A.robot (Size: 657.98 KB / Downloads: 209)
What do you mean by POS?
I you want us to add a robot we would need the 3D model and spec sheet of the robot.
*POS significa Pós-processador; uma mensagem aparece no robô de 4 eixos.
"Falha ao gerar o programa "1" usando o Pós-processador "Borunte"
Caminho do pós-processador: C:/RoboDK/Posts/Borunte.py
File "C:\Users\Cliente\AppData\Local\Temp\Post1.py", line 32, in
r.MoveJ(None,[0,0,0,-2.712e-31],None)
File "Borunte.py", line 426, in Borunte.RobotPost.MoveJ
IndexError: list index out of range
Saída do processo:
Usando a versão do Python: sys.version_info(major=3, minor=10, micro=10, releaselevel='final', serial=0)
Pós-processador RoboDK: C:\RoboDK\Posts\Borunte.py
Total de instruções: 2
Código de saída do processo do pós-processador Python: 1"
**Seguem as especificações técnicas.
.pdf   BRTIRPZ2080A robot technical recommendation.pdf (Size: 538.27 KB / Downloads: 237)
.pdf   BRTIRPZ2080A-四轴立柱码垛机器人轨迹图-V1版本-2025.12.18.PDF (Size: 190.96 KB / Downloads: 241)
I'm unable to reproduce this issue with the latest version of RoboDK. Are you using the latest version?
Can you provide the RDK file that provokes this issue?
Attachments follow for analysis.
link to video:
https://drive.google.com/drive/folders/1...sp=sharing
.rdk   ESTUDO 1.rdk (Size: 2.44 MB / Downloads: 223)
Thank you for sharing, but I'm unable to reproduce this issue.
You may have changed some settings in the Tools-Options-Program tab (such as the output type for joint or linear movements).
I recommend you to try setting the default settings back by selecting Tools-Options-Set default settings.
I left the default settings as requested. The error persists. Could you send me a screenshot of the ideal settings so I can post-process it?
