Adept Cobra S350 fails to connect
Good day, community.
I have an Adept Cobra S350 robot connected with its controller and all, the robot does connect properly with the official Adept software (ACE), but I'm having problems trying to connect the robot with RoboDK.
Whenever I attempt to connect, I get an "execvp: No file or directory (0)" error on the log. It seems like it tries to load a driver called "AdeptDriver" inside "RoboDK/bin/", but such driver doesn't exist.
If I run the ping on the connection options, it does mark it as being successful, so I'm not sure if it's a problem with the port number, or if the driver I should choose for it is missing and/or should be another from the list.
Thanks in advance!
We don't have a driver for Adept robot controllers. However, you should be able to generate programs for Adept robots without issues:
  1. Right click a program
  2. Select Generate robot program
You can find more information about generating programs offline here:
https://robodk.com/doc/en/Robot-Programs...ateProgram
