Api c# Point Follow Project
Question
Hello , can I access to the points of a point follow projects one by one (like individual targets) from de c# api?
Thanks!
Hi Amartinmestres,
You'll have to clarify your question a bit.
If you didn't create a Curve Follow Project (CFP) the points are available from "GetPoints": https://robodk.com/doc/en/PythonAPI/robo....GetPoints
If your CFP is already created and updated, you can extract the target from the created program. If you right-click the program in the UI and select "show instruction" you will see all the instructions.
You can then select any Move, right-click and "select target" to extract the target. The same data should be available from the API I believe.
Ok thanks
Hi Amartinmertres,
According to the documentation, MoveJ and MoveL accept 3 types of positional information.  https://robodk.com/doc/en/PythonAPI/robo...Item.MoveL
1 - A target
2 - List of joints
3 - 4X4 matrix
So something like
prog.MoveL(Pose) should be enough. No need to create the target itself.
According to this example (https://robodk.com/doc/en/PythonAPI/exam...structions), you can feed that information directly to the Move in your program.
elif instruction_dict['Type'] == INS_TYPE_MOVE:
       print("Move instruction: use setInstruction to modify target")
       #ins_name, ins_type, move_type, isjointtarget, pose, joints = prog.Instruction(ins_id)
       #prog.setInstruction(ins_id, ins_name, ins_type, move_type, isjointtarget, pose, joints)
In the link you sent it's say
"Move a robot to a specific target (“Move Joint” mode). This function waits (blocks) until the robot finishes its movements. If this is used with a program item, a new joint movement instruction will be added to the program. Important note when adding new movement instructions to programs: only target items supported, not poses"
I can't add a instructions with a pose only with a item traget and it's too slow
Hi There,
Sorry for that.
Have you try turning down the render before starting your script and turning it on again afterward?
RDK.Render(False)
(Code)
(You need to add RDK.Update() after you move a target or an object)
RDK.Render(True)
6 Guest(s)
