Hi - I am working with the Fusion 360 addon to generate RoboDK milling paths. Works great except I can figure out how to override the initial set speed. It remains at 1000mm/sec no matter what the settings in Fusion. Cant find anything in the help files. Can someone tell me where it is set? Thanks.
Autodesk Fusion 360 initial set speed for robot machining |
07-29-2024, 08:53 AM
You can set the default approach speed by and other program events by clicking on Program Events and updating the Fast Move Speed (in mm/s).
You can find more information here: https://robodk.com/doc/en/Robot-Machinin...ningEvents
07-30-2024, 12:17 AM
(07-29-2024, 08:53 AM)Albert Wrote: You can set the default approach speed by and other program events by clicking on Program Events and updating the Fast Move Speed (in mm/s). Awesome - so easy thanks. |
| 1 Guest(s) |
Powered by MyBB
