Hi guys,
I am using the offline programming using keyboard to control the robot. This is just a base for a bigger project I am working on. I am trying to move the robot to a a set position in-case it reaches singularity. The code I tried is:
I got the values for robot_joints1, by printing the value of the robot.joints of my target position. In the code I tried inputting these joint value to the robot, to go incase it reaches singularity. I am getting no errors but the robot is not moving to the set joint values( the robot is not moving at all). I am trying to make the robot move to a target position if it encounters singularity.
Also,I understand the code and how it moves the robot end-effector on the x,y,z axis but I also wanted to know if its possible to control the rotation of the end effector or the orientation of the end effector using the keyboard ? I printed out the new_robot_position and saw that only the x,y,z, changed while the angles were constant at 0,90,0. I wanted to to if I can manipulate the angles as well using keyboard keys.
I want the starting pose to be - Pose (490.000, 0.000, 780.000, 0.000, 90.000, 0.000) and instead of moving the xyz as shown in the example, is there a way to manipulate the pose ,like adding or subracting from the above Pose value? Something like the below code (not working and wrong syntax but just show you what I mean):
# This macro allows moving a robot using the keyboard
# More information about the RoboDK API here:
# https://robodk.com/doc/en/RoboDK-API.html
# Type help("robolink") or help("robodk") for more information
# Press F5 to run the script
# Note: you do not need to keep a copy of this file, your python script is saved with the station
from robolink import * # API to communicate with RoboDK
from robodk import * # basic matrix operations
RDK = Robolink()
# Arrow keys program example
# get a robot
robot = RDK.Item('', ITEM_TYPE_ROBOT)
if not robot.Valid():
print("No robot in the station. Load a robot first, then run this program.")
pause(5)
raise Exception("No robot in the station!")
print('Using robot: %s' % robot.Name())
print('Use the arrows (left, right, up, down), Q and A keys to move the robot')
print('Note: This works on console mode only, you must run the PY file separately')
# define the move increment
move_speed = 10
robot_joints1= [ 8.805 , -13.848 , 0.000, -97.620, 0.849, 90.965, 145.752 ]
print(robot_joints1)
from msvcrt import getch
while True:
RDK.Render(True)
key = (ord(getch()))
move_direction = [0,0,0]
# print(key)
if key == 75:
print('arrow left (Y-)')
move_direction = [0,-1,0]
elif key == 77:
print('arrow right (Y+)')
move_direction = [0,1,0]
elif key == 72:
print('arrow up (X-)')
move_direction = [-1,0,0]
elif key == 80:
print('arrow down (X+)')
move_direction = [1,0,0]
elif key == 113:
print('Q (Z+)')
move_direction = [0,0,1]
elif key == 97:
print('A (Z-)')
move_direction = [0,0,-1]
# make sure that a movement direction is specified
if norm(move_direction) <= 0:
continue
# calculate the movement in mm according to the movement speed
xyz_move = mult3(move_direction, move_speed)
# get the robot joints
robot_joints = robot.Joints()
# get the robot position from the joints (calculate forward kinematics)
robot_position = robot.SolveFK(robot_joints)
# get the robot configuration (robot joint state)
robot_config = robot.JointsConfig(robot_joints)
# calculate the new robot position
new_robot_position = transl(xyz_move)*robot_position
print(new_robot_position)
# calculate the new robot joints
new_robot_joints = robot.SolveIK(new_robot_position)
if len(new_robot_joints.tolist()) < 6:
#print("No robot solution!! The new position is too far, out of reach or close to a singularity")
new_robot_config = robot.JointsConfig(robot_joints1)
#robot.MoveJ(robot_joints1)
#continue
else:
# calculate the robot configuration for the new joints
new_robot_config = robot.JointsConfig(new_robot_joints)
if robot_config[0] != new_robot_config[0] or robot_config[1] != new_robot_config[1] or robot_config[2] != new_robot_config[2]:
print("Warning!! Robot configuration changed!! This will lead to unextected movements!")
#print(robot_config)
#print(new_robot_config)
else:
# move the robot joints to the new position
robot.MoveJ(new_robot_joints)
#robot.MoveL(new_robot_joints)
x=0
y=0
z=0
a=0
b=0
c=0
robot_position= (490.000, 0.000, 780.000, 0.000, 90.000, 0.000)
while True:
RDK.Render(True)
#move_direction = [0,0,0]
# print(key)
if key == 75:
y=y-5
elif key == 77:
y=y+5
elif key == 72:
x=x-5
elif key == 80:
x=x+5
elif key == 113:
print('Q (Z+)')
z=z+5
elif key == 97:
print('A (Z-)')
z=z-5
#if norm(move_direction) <= 0:
#continue
#xyz_move = mult3(move_direction, move_speed)
#print (xyz_move)
#print(robot_position)
new_robot_position.pose = (490.000+x, 0.000+y, 780.000+z, 0.000, 90.000, 0.000)#transl(xyz_move)*robot_position
#print(new_robot_position)
new_robot_config = robot.JointsConfig(robot_joints)
continue
else:
else:
