Hello.
I cloned the RoboDK-API repo, tried to run the project from Visual Studio (tried versions 2017 and 2019) and got System.FormatException at RoboDK.cs line 584, as the previous line
returns "RoboDK top level window was not found..." instead of int descriptor of the window. This happens both if the RDK is opened previously before the project is run, or if the RDK is not running.
I couldn't find much help on the toppic, the thread
https://robodk.com/forum/Thread-Problem-...ws-8-64bit
didnt help.
https://github.com/RoboDK/RoboDK-API/issues/60
Previous instance of the RoboDK IDE was left open somewhere (OS warned me that existing opened instance is preventing the PC to reboot, couldn't find it otherwise), causing socket communication from 2nd instance to get aborted and disconnected from the host - socket is opened, but the "VerifyConnection" method finds out that the connection is closed - but desn't handle this state.
var mainWindowId = Command("MainWindow_ID");returns "RoboDK top level window was not found..." instead of int descriptor of the window. This happens both if the RDK is opened previously before the project is run, or if the RDK is not running.
didnt help.
