Calculate the length of the curves within the Curve Follow Project
is there a way to find the length of one or more curves within a curve follow project? It should exclude the lengths of approach, retract, or idle paths. I only want to see the total length of the actual processed surface.
In the example I provided, the length of a single path is 1500mm. In reality, the total length of the processed surface should be 4500mm, but when I use CycleTime scripts, it doesn't give me what I want.
.rdk   CurveLenght.rdk (Size: 4.63 MB / Downloads: 376)
This is currently not possible (either using the API or the UI), but if you have a Professional license you can contact us through our contact form mentioning this thread and we can find a solution:
https://robodk.com/contact
