03-29-2022, 08:14 PM
Hi everyone!
My plan would be to create a simulation, so are there codes for Arduino?
Thanks!
Thanks!
Can RoboDK run in aurduino? |
Hi everyone!
My plan would be to create a simulation, so are there codes for Arduino? Thanks!
03-30-2022, 08:03 PM
It really depend on what you want to do.
If you want to make a robot with an Arduino and then control it with RoboDK, it is possible, but the Arduino alone is not powerful enough to simulate the reverse kinematic of an 6 axis robot. I suggest you take a look at Chris Annin AR4 robot if you are looking for that kind of project.
03-31-2022, 12:35 AM
If you are looking to run RoboDK in a small device you won't be able to do it on any microcontroller but any microprocessor based mini computer capable of running Linux should work just fine.
You can take a look at this quick guide on how to install RoboDK in a Raspberry Pi. https://robodk.com/blog/robodk-for-raspberry-pi/ |
| 1 Guest(s) |
