Change how tool moves with "curve follow project"
Hi!
When the robot finishes welding this path, the robot goes uphill. How do I fix this? I want it to go out of the place it is welding an not crash when it moves out. instead it crash straight into the side as shown in picture 2.. I use "curve follow project" to select path .. (I can not adjust the angle more because then it will crash to the component while welding)
Best regards Kari
Hi Kari,
This video explains how to use a RoboDK with a plugin.
Around 9:33 I'm explaining the concept of approach and retract.
https://youtu.be/NoefxDYIwFA?t=573
It worked. Thank you so much!
Have a great day!
Best regards Kari
