04-29-2025, 09:14 AM
(This post was last modified: 04-30-2025, 07:44 AM by Albert.)
I'm currently working on a RoboDK KukaOfficelite and TwinCAT simulation.
The real robot uses collision sensors and sends this to TwinCAT.
I want to use RoboDK's collision checking and set a variable when triggered (by a gripper or robot) and send this variable to TwinCAT (ads).
How do I evaluate the status of the collision check in RoboDK using Python?
04-29-2025, 10:55 AM
(This post was last modified: 04-30-2025, 07:43 AM by Albert.)
Thanks. I know about the OPC plugin. But the TwinCAT (ads) part I can use from older projects.
224
What do you mean by the TwinCAT / ads part?
I use Pyads. In the PLC (here 3), I use input/output variables (structs) that are linked to the robot via Ethercat hardware in real-world operation. In the simulation, I read/write them via Pyads and connect them via RoboDK/KukaOfficelite. Every robot has the same structure, so this is a library. Some time ago, I used other expensive drivers for Twincat-KukaOfficeLite communication. But it doesn't have to be that way . I just see I have been using RoboDk for ca. 10 years
224
OK I understand better know. Thanks for this information.
So you should be able to communicate with TwinCAT without paid modules using Python. Another option is to use plain Modbus or OPC-UA. There are Python modules. For example, we use pymodbus to communicate with Omron TM robots when you use the driver for this robot.
years ago, I used RoboDK with Modbus. I purchased a tool for this. But 90% of my customers use TwinCAT, and almost all of them have a fixed structure how they communicate with the robot. Now I have an ADS connection between RoboDK and the PLC, and in RoboDK, I link all the signals to Kuka.Officelite. (Until I find a way to establish The EtherCAT connection in Kuka.Officelite.)
In RoboDK, I then manipulate the robot signals, as product in the gripper, crash sensors, etc.
224
OK thank you for your feedback. Let us know if you need help with your integration between RoboDK and EtherCAT.
