Connection To Leica : python errorImport Error: No module named 'clr'
When I try to connect to leica I have the following message in log:
Unexpected error: File "C:/RoboDK/api/Leica/LeicaTrackerPilot.py", line 694, in <module>
Unexpected error: import clr
Unexpected error: ImportError: No module named 'clr'
Stopped
I tried to uninstall robodk and Python and reinstalled it. This seems a problem with python.net installation?
Thanks for the help
Problem solved :
It seems that when 'Install-Pythonnet.bat' was called by roboDK installer the path to python.exe was wrong.  In the command prompt (cmd.exe) I ran 'python.exe -m pip install pythonnet' from directory RoboDK\Python37 .
Perfect! Thank you for reporting this issue.
We'll update RoboDK to provide a better error message to point in the right direction.
