Controlling multiple robots
Is it possible to control more than one robot in RoboDK where a supervisory PLC is used to monitor and coordinate the movement between robots?.
From a simulation perspective or with real robots?
(02-18-2021, 04:28 PM)Jeremy Wrote: From a simulation perspective or with real robots?
From simulation perspective where modeled robots perform what real robots do, as in a digital  twin. But two robots
Are you planning on using a real PLC or a PLC simulator? Or simulating one in another way?
RoboDK has an OPC UA feature that could help you. I would recommend you to search out the forum for more info.
Thank you, Yes. I was thinking of using a real PLC to issue commands for my virtual robots in a collaborative way
Ok good, therefore I think that OPC UA is your best bet.
