I need help, in the factory is now one ABB robot and the factory will to change for Fanuc .I will to convert everything what is possible from abb to fanuc.
Convert ABB programs to Fanuc |
06-04-2024, 10:17 PM
Although it is not officially supported to import any type of robot program in RoboDK, with RoboDK you should be able to load some program files (such as MOD files from ABB, LS files from Fanuc, JBI files from Motoman robot controllers, or SRC files from KUKA robot controllers). You should first load your robot in your project and then import the program file to see the result.
You can also customize the behavior of the import process. This sample script shows how to customize the import of KUKA SRC program files as RoboDK programs: https://robodk.com/doc/en/PythonAPI/exam...a-src-file |
Users browsing this thread: |
1 Guest(s) |
Powered by MyBB
