05-22-2025, 06:02 PM
Hey!
I just started with RoboDK and want to use the python API to write a simple Picking simulation. For that, I create three Frames (for three pick-up stations) and for each frame, I create two Targets, one without an offset (grasping position) and one 100mm above the Frame (pre-grasp). Both Targets are children of the corresponding frame and now I want to move between those Targets.
After a bit of experimentation in the GUI, I found out that I need to set the Reference Frame before calling a MoveJ to the next target. I had assumed that I can call a MoveJ on a target and the robot position will be computed by traversing the tree upwards until we find the robot base.
Why was it implemented this way? When would I use a Reference Frame that is not the parent of a Target when calling a Move-command with the Target?
