Custom mechanism gripper detaches along with object
I am working on a dual JAKA cobot project in RoboDK and have designed a custom two-finger gripper using RoboDK's Mechanism Builder. The gripper functions correctly and is attached to the robot as shown in the attached video.
However, I am facing an issue when using RoboDK's Attach to Tool and Detach from Tool instructions.
When the robot picks the needle, the attachment works as expected. However, during the release operation, when I execute the Detach from Tool instruction, RoboDK not only detaches the needle but also detaches the entire gripper mechanism from the robot.
The gripper was created using the Mechanism Builder and is saved/loaded as a mechanism (robot) rather than a standard tool. My current station tree and behavior can be seen in the attached video.
Could someone please help me understand:
  1. Why is the gripper also being detached when I only want to release the needle?
  2. Is my station tree structure correct for a custom gripper created using the Mechanism Builder?
  3. Should the picked object be attached directly to the robot tool frame rather than becoming a child of the mechanism?
  4. Is there a recommended way to implement object handover when using custom mechanism-based grippers?
  5. Would using the RoboDK Python API (for example, setParentStatic) be a better approach than the built-in Attach/Detach instructions for this type of application?
The attached video shows the exact behavior. Any guidance on the correct station structure or object attachment method would be greatly appreciated.
Thank you.
For simulation purposes you could add a new tool to the gripper and attach the object to that tool.
Can you share your RoboDK project file? We can better take a look and help you. Also, you are referring to a video that is not attached.
The issue is somehow resolved but I don't know whether it's reliable or not. I have attached the file, kindly confirm the required tree structure is valid and reliable. Thank you
.rdk   RoLL_Project - 11062026 - v1.rdk (Size: 8.85 MB / Downloads: 130)
I'm sorry for the delays. I meant more in this manner:
  1. The tool directly attached to the robot
  2. Objects are attached to the tool when they are grabbed
  3. The gripper directly attached to the robot (or via a coordinate system)
Even if the gripper moves it is better to keep the TCP static as most robot controllers need one fixed TCP to operate and move the robot.
I attached an image and your project with these edits.
Let us know when you have a program so we can better help you point in the right direction.
.rdk   RoLL_Project - 11062026 - v2.rdk (Size: 8.85 MB / Downloads: 61)
