11-29-2021, 02:34 PM
When I drag over the ALL.PRM file to RoboDK I get the following error as shown in image attached
Error on ALL.PRM import |
11-29-2021, 11:47 PM
There is no image attached.
11-30-2021, 01:34 PM
Here is the screen shot that I thought I had attached
11-30-2021, 02:00 PM
Did you select the correct robot in RoboDK? It looks like there is a 365 mm error on the length of the arm (d4).
If you can send us your RoboDK project and the ALL.PRM we can better take a look.
11-30-2021, 03:38 PM
Here are the 2 files as requested The robot I chose was an ER165D the one I am using is a ES165N. I will have to find the manuals for dimensional data. I renamed the ALL.PRM to ALL.rdk as the system would not let me attach a .PRM file
10-09-2025, 05:07 PM
You can take the latest version here: https://robodk.com/download Make sure to first load the correct robot model from the RoboDK library and then load the ALL.PRM file. If you have any issues, try using the default Python interpreter (C:/RoboDK/Python-Embedded). |
| 1 Guest(s) |
