The attached error pops up after selecting Tools->Run Script->Import CSV XYZWPR.
Studying on 6.7. CSV file to Program (XYZWPR).
Error whe I select Import CSV XYZWPR |
07-03-2025, 09:56 PM
Can you share the CSV file you are trying to load?
You probably didn't provide the 6 values required for each line.
07-04-2025, 02:01 AM
(07-03-2025, 09:56 PM)Albert Wrote: Can you share the CSV file you are trying to load? As attached
Example-Import-CSV-XYZWPR.zip (Size: 11.28 KB / Downloads: 92)
07-04-2025, 06:42 AM
I'm unable to reproduce this issue. Did you see the error with the same file you shared? Can you share the RoboDK project you are using?
07-07-2025, 12:35 PM
UR10e xyzwpr import.rdk (Size: 3.25 MB / Downloads: 100)
(07-04-2025, 06:42 AM)Albert Wrote: I'm unable to reproduce this issue. Did you see the error with the same file you shared? Can you share the RoboDK project you are using?
07-08-2025, 08:43 AM
You should add a tool for your program and a coordinate system to place the targets. You can do so from the Program menu. I can the run the script and load the CSV file you provided without issues.
07-08-2025, 10:14 AM
07-09-2025, 08:06 AM
Thank you for letting us know.
| 1 Guest(s) |
