I have exported robot machining project from Fusion360 to RoboDK. Now I would like to run some additional tests regarding path feasibility in Matlab. I need to import robot joints / transformation matrices of the points on the machining path into Matlab. One way to do it, is to generate robot program with Robodk, input that script file into Matlab and write a code to extract the lines with joint positions. Is there any simpler way? Is it possible to get those values from the machining project in the Robodk in form of Targets? Those targets could then be directly sent to Matlab via API.
Thank you in advance.
Best regards.
Best regards.
