Exporting joints position of a 6 axis robot
I'm using the JointsSpeedAccel.py Macro to export joints positions of a 6 axis robot. I would like to know what correspond to the value of the position of each axis exported ? Are there polar coordinates ?
I thought that macro export joints position in cartesian coordinates with euler angles.
Thanks,
Yohan
.rdk   Nouvelle Station (1).rdk (Size: 416 KB / Downloads: 653)
The script exports the joint values of the robot, in degrees.
You can modify the script to add the Cartesian values.
# This script generates a chart of the simulated joints calculating joint speeds and accelerations
# Tip: Use the script JointsPlayback.py to move along the recorded joints
from robolink import *    # API to communicate with RoboDK
from robodk import *      # basic matrix operations
from time import gmtime, strftime, time
# Simulation ratio: lower is more accurate
SimulationSpeed = 0.05 # A program that takes 5 seconds in real time, will be SimulationSpeed times faster in simulation (or slower if < 1)
# Sampling time: how often we want a new entry
SampleTime = 0.05
# To get better results:
# Select tools-Options-Motion
# Set Maximum path step (mm) to 0.01
# Set Maximum path step (deg) to 0.01
# Start RoboDK API
RDK = Robolink()
t_ratio = 1/SimulationSpeed
RDK.setSimulationSpeed(SimulationSpeed)
# Ask the user to select a robot arm (mechanisms are ignored)
prog = RDK.ItemUserPick('Select a program',ITEM_TYPE_PROGRAM)
if not prog.Valid():
   raise Exception("Robot is not available")
robot = prog.getLink(ITEM_TYPE_ROBOT)
ndofs = len(robot.Joints().list())
# Generate a file in the same folder where we have the RDK file
file_path = RDK.getParam('PATH_OPENSTATION') + '/joints-' + prog.Name() + '.csv'
def joints_changed(j1, j2, tolerance=0.0001):
   """Returns True if joints 1 and joints 2 are different"""
   if j1 is None or j2 is None:
       return True
   for j1,j2 in zip(j1,j2):
       if abs(j1-j2) > tolerance:
           return True
   return False
def diff(j1, j2, dt, dofs):
   if j2 is None or dt <= 0:
       return [0]*dofs
   res = []
       res.append((j1-j2)/dt)
   return res
# Infinite loop to record robot joints
print("Recording robot joints to file: " + file_path)
with open(file_path,'w') as fid:
   joints_header = ",".join(["Joint " + str(i+1) for i in range(ndofs)])
   speeds_header = ",".join(["Speed " + str(i+1) for i in range(ndofs)])
   accel_header = ",".join(["Accel " + str(i+1) for i in range(ndofs)])
   xyzwpr_header = ",".join(["X", "Y", "Z", "W", "P", "R"])
   fid.write("Time (s)," + joints_header + ",,Time (s)," + speeds_header + ",,Time (s)," + accel_header + ",,Time (s)," + xyzwpr_header)
   fid.write("\n")
   joints_last = None
   speeds_last = None
   t_last = None
   t_start = None
   RDK.Render(True)
   prog.RunProgram()
   while prog.Busy():
       #t_now = time() # Estimate using t_ratio
       #t_now = float(RDK.Command("SimulationTime"))*0.001
       t_now = float(RDK.Command("TrajectoryTime")) # RoboDK's internal clock for motion simulation
       joints = robot.Joints().list()
       if joints_changed(joints, joints_last):
           if t_last is None:
               t_last = t_now
               t_start = t_now
           # Calculate timings
           #t_sim = t_ratio * (t_now - t_start) # not needed if we use RoboDK's SimulationTime
           #t_delta = t_ratio * (t_now - t_last) # not needed if we use RoboDK's SimulationTime
           t_sim = t_now - t_start
           t_delta = t_now - t_last
           if t_delta < SampleTime:
               # Minimum 5 ms time for good accuracy
               continue
           # Calculate speeds
           speeds = diff(joints, joints_last, t_delta, ndofs)
           # Calcualte accelerations
           accels = diff(speeds, speeds_last, t_delta, ndofs)
           # Calculate xyz
           xyzwpr = pose_2_xyzrpw(robot.Pose())
           print('Time +S: %.3f s' % t_sim)
           joints_str = ",".join(["%.6f" % x for x in joints])
           speeds_str = ",".join(["%.6f" % x for x in speeds])
           accels_str = ",".join(["%.6f" % x for x in accels])
           xyzwpr_str = ",".join(["%.6f" % x for x in xyzwpr])
           time_str = ("%.6f," % t_sim)
           fid.write(time_str + joints_str + ",," + time_str + speeds_str + ",," + time_str + accels_str + ",," + time_str + xyzwpr_str)
           fid.write("\n")
           t_last = t_now
           joints_last = joints
           speeds_last = speeds
           #pause(0.005)
This script only exports joint values, not Cartesian.
You can calculate the Cartesian position of your robot effector using SolveFK.
