Frequently Asked Question (FAQ) about the RoboDK Python API
Q: What is the RoboDK Python API?
A: The RoboDK Python API is a programming interface that allows you to communicate with the RoboDK software using the Python programming language.
Q: What are some common use cases for the RoboDK Python API?
A: Some common use cases for the RoboDK Python API include:
A: RoboDK depends on the Python API for the following components:
A: To use the RoboDK Python API, you should have a basic understanding of programming concepts and experience using Python. It may also be helpful to have some knowledge of robotics.
Q: How do I install the RoboDK Python API?
A: To install the RoboDK Python API, download and install RoboDK. RoboDK ships with a matching version of the Python API under %ROBODK_FOLDER%/Python, which is added to %PYTHONPATH%. The RoboDK Python API is also available on the Python Package Index (PyPI): https://pypi.org/project/robodk/.
Q: How do I get started with the RoboDK Python API?
A: To get started with the RoboDK Python API, you can read the documentation, try the examples provided, and experiment with your own code: https://robodk.com/doc/en/PythonAPI/index.html.
Q: Is the RoboDK Python API free to use?
A: Yes, the RoboDK Python API is free to use with the RoboDK software. However, you may need to purchase a license for RoboDK depending on your specific use case.
Q: Where can I learn more about the RoboDK Python API?
A: Below are some relevant links for the Python API:
A: Yes, you can set the desired Python interpreter in Tools->Options->Python. You are responsible for installing required dependencies if you provide your own interpreter.
Q: How can I install the RoboDK Python API through pip in my own Python interpreter?
A: Note that RoboDK will always add C:/RoboDK/Python/ to %PYTHONPATH% when launching scripts from RoboDK (more information on %PYTHONPATH% here: https://docs.python.org/3/using/cmdline....PYTHONPATH).
To use the RoboDK Python API that ships with your version of RoboDK, use the following pip command (Windows):
To install the latest version of the RoboDK Python API from PyPI, use the following pip command (Windows):
Q: Python is reporting errors when I "Generate Robot Program". What should I do?
A: Python errors when generating robot programs with our post processors is often due to the Python interpreter.
- Generating robot programs automatically based on CAD models or other data
- Simulating robot movements to validate programs before running them on a real robot
- Controlling external devices, such as sensors or grippers, using robot movements
- Customizing the user interface of RoboDK to meet specific needs
- RoboDK robot post processors
- RoboDK robot drivers, and other external devices
- RoboDK Apps (Python add-ins)
- RoboDK Docs: https://robodk.com/doc/en/RoboDK-API.html#PythonAPI
- RoboDK Python Docs: https://robodk.com/doc/en/PythonAPI/index.html
- RoboDK Python Examples: https://robodk.com/doc/en/PythonAPI/examples.html
- RoboDK API GitHub: https://github.com/RoboDK/RoboDK-API/tree/master/Python
- PyPI: https://pypi.org/project/robodk/
C:/path/to/python.exe pip install -e C:/RoboDK/Python/.To install the latest version of the RoboDK Python API from PyPI, use the following pip command (Windows):
C:/path/to/python.exe pip install robodk --upgradeQ: Python is reporting errors when I "Generate Robot Program". What should I do?
- Make sure that the Python interpreter is valid: RoboDK->Tools->Options->Python.
- Alternatively, you can "Set the Default Python settings".
