Failed to generate program-Invalid Python version
Hi, I got below message when I tried to generate a program, can you help please? I attached the py file as well.
Failed to generate program "Curve" using the Post Processor "ABB_RAPID_IRC5"
Post processor path:C:/RoboDK/Posts/ABB_RAPID_IRC5.py
File "C:\Users\Administrator\AppData\Local\Temp\PostCurve.py", line 15, in
from ABB_RAPID_IRC5 import *
File "C:\RoboDK\Posts\ABB_RAPID_IRC5.py", line 33, in
raise Exception(msg)
Exception: Invalid Python version or post processor not found. Make sure you are using a supported Python version: C:/RoboDK/Posts/v311
Select Tools-Options-Python and select a supported Python version
Process output:
Using Python version: sys.version_info(major=3, minor=11, micro=4, releaselevel='final', serial=0)
RoboDK Post Processor: C:/RoboDK/Posts
Python Post Processor process exit code: 1
You can solve the invalid Python version issue when generating your program by following these steps:
  1. Select Tools-Options
  2. Select the Python tab
  3. Enter the following path as the Python interpreter: C:/RoboDK/Python-Embedded/python.exe.
 I followed below steps, but unfortunately, I got same message.
Image(s)
.py   PostCurve.py (Size: 6.8 KB / Downloads: 327)
What version of RoboDK are you using?
If you are under maintenance, can you try updating RoboDK?
