05-31-2023, 08:41 AM
OK that makes sense. Updating to the latest version of RoboDK should work with all versions of Python.
Failed to generate program using the Mitsubishi Post Processor |
05-31-2023, 11:45 AM
I only used the latest version. And the default setting in robodk was to use the system python (3.10) which couldnt move the axis, then I needed to switch to 3.7 where I am now and getting consistenly the error "AttributeError: 'list' object has no attribute 'lower'"
05-31-2023, 08:45 PM
Do you mean you still see the error you mentioned in your previous post here?
https://robodk.com/forum/Thread-Faliled-...4#pid14794 Can you share the RDK file you used to see that error?
06-01-2023, 03:15 PM
Yes unfortunately im still getting the error
Attached is the rdk
06-02-2023, 08:30 AM
The RDK file was not attached. Could you please provide it so we can investigate further?
07-23-2023, 07:40 AM
Apparently I didnt click "Add attachment".
I needed to work on other projects in the meantime. Unfortunately the test license ran out but here is the file anyway. I didnt make any progress after that. One more thing that I noticed which I cant verify now anymore is that when creating G-Code it offsets the base coordinate in the wrong direction. If I remember correctly I needed to change the signs of the base coordinate shift to make the code run like in the TestStationRV.dk I wouldve prefered to not the shift the base coordinates at all but that was likely my mistake somewhere? Thank you and sorry for the inconvenience of the delay.
07-24-2023, 05:19 PM
I tried reproducing this error but I didn't see any issues and I was able to obtain the PRG file.
Make sure to enter the Python embedded path as Python interpreter. You can do so by following these steps:
Can you try updating RoboDK to the latest version? You can contact us through our contact form and we can send you a trial extension. |
Users browsing this thread: |
1 Guest(s) |
