08-18-2020, 02:05 PM
robodk@sw1 ~/RoboDK/bin $ LD_LIBRARY_PATH=./lib gdb ./RoboDK
GNU gdb (Gentoo 9.1 vanilla) 9.1
Copyright © 2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://bugs.gentoo.org/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./RoboDK...
(No debugging symbols found in ./RoboDK)
(gdb) run
Starting program: /home/robodk/RoboDK/bin/RoboDK
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
[New Thread 0x7fffe4138700 (LWP 2357)]
[New Thread 0x7fffdbfff700 (LWP 2358)]
[New Thread 0x7fffdb7fe700 (LWP 2359)]
No running instances of RoboDK detected
Starting RoboDK v 5.0.2 . 18542 ...
OS: LIN64
Date build: Aug 16 2020
Main process ID: 2353
Thread ID: 0x7ffff1cfa040
[New Thread 0x7fffd32aa700 (LWP 2360)]
Loading settings...
Failed to acces global parameters file
Setting up default settings...
Default settings set
Settings loaded
Statusbar: "Language set to English"
Updating recent files menu...
Created language menu
[New Thread 0x7fffd2806700 (LWP 2361)]
Setting slider style...
Done
Setting up graphics...
Setting up main window...
Starting main window...
LC start...
LC message: LC device not found
Dongle not found or cannot read
LC start...
Loading plugin: "CollisionFreePlanner"
"libAppLoader.so"
"libCollisionFreePlanner.so"
Loading plugin file: "libCollisionFreePlanner.so"
Loading plugin "CollisionFreePlanner"
Using settings: ""
Setting up the status bar
Inserting menu at the end of the utilities menu
Setting up the menu bar
"libOPC-UA.so"
"libPluginExample.so"
"libPluginGravity.so"
"libPluginPalletizing.so"
"libPluginRealTime.so"
"libRobotPilot.so"
List of LOADED plugins:
Done list of plugins
Statusbar: "Loaded 1 plugins"
Reading preferred layout settings...
Done
Thread 1 "RoboDK" received signal SIGSEGV, Segmentation fault.
0x00007ffff67cd454 in QOpenGLContext::functions() const () from ./lib/libQt5Gui.so.5
(gdb)
##########3
robodk@sw1 ~/RoboDK/bin $ modinfo nvidia
filename: /lib/modules/5.5.0-gentoo-x86_64/video/nvidia.ko
alias: char-major-195-*
version: 440.82
supported: external
license: NVIDIA
srcversion: 058C3165C621D73A1F7436F
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends: ipmi_msghandler,i2c-core
retpoline: Y
(gdb) run
OS: LIN64
Loading settings...
Settings loaded
Done
LC start...
LC start...
"libAppLoader.so"
Using settings: ""
"libOPC-UA.so"
"libRobotPilot.so"
Done
(gdb)
##########3
version: 440.82
supported: external
license: NVIDIA
retpoline: Y
