Fanuc M-710iD/50M library robot: joints do not match the controller
The Fanuc M-710iD/50M of the online library (Fanuc-M-710iD-50M.robot, md5 40934a4583cc11a544417c88534d838b, RoboDK 6.1.1) does not count its joints like the real controller (R-30iB Plus). A joint target posted from RoboDK sends the real robot to a different posture.
To reproduce, with the library file alone:
1. Load Fanuc-M-710iD-50M.robot in an empty station.
2. Set the joints to 0, 0, 30, 0, 0, 0. The forearm goes 30 deg below the horizontal (flange Z from 1884.9 to 1131.1 mm). On the real robot, J3 = +30 is 30 deg above the horizontal.
3. Post a MoveJ to that pose with Fanuc R30i. The .LS reads J3 = 30.000 deg.
4. Same test with Fanuc-M-710iC-50.robot and the same post: the forearm goes 30 deg up and the .LS reads J3 = 30.000 deg, which is consistent.
What we found, checked against three poses read on our controller (flange orientation within 0.013 deg with this conversion, 53 deg or more away with any other sign combination):
- model J3 = -(controller J2 + controller J3)
- J4, J5 and J6 reversed
- flange frame turned 180 deg about its Z axis
- base frame on the mounting face, where the M-710iC/50 file has it at the J2 axis (565 mm higher), like the controller's world origin
- J2 limit +/-112.5 in the file, -75 / +150 on the controller; J3 +/-220 in the file, -160 / +280 on the controller
- link dimensions up to 7.8 mm away from the FANUC manual B-84664EN/01, Fig. 3.2 (b) (file: 563.4, 150.6, 1157.8, 163.7, 1294.3, 169.6 mm; manual: 565, 150, 1150, 170, 1295, 175), plus a 1.0 mm lateral offset
The post does not seem to be the cause: the Fanuc RJ3 post writes the same joints with this file.
Could the library file be corrected? And is there another version of this robot file that follows the controller's convention?
Attached: the four .LS files of the test (both robots, the J3 = 30 pose and a general pose, Fanuc R30i post) and the three controller poses.
Thank you,
.zip   M-710iD-50M_joint_convention.zip (Size: 3.77 KB / Downloads: 13)
Fanuc robots have coupling for joints 2 and 3, sometimes the range of motion for joint 3 changes as joint 2 changes, so it is not a perfect parallelogram. You should update the allowed area for joint space for axes 2 and 3 from your controller to RoboDK by sampling some points on the limits.
You should update the chart of allowed space for joints 2 and 3 by double clicking on the label of the joint limits. You can find more information here:
https://robodk.com/doc/en/General.html#CoupledJoints
Thanks Albert. We set the J2/J3 area that way, with the values read on our R-30iB Plus controller:
- J2: -75 / +150 deg, J3: -160 / +280 deg ($PARAM_GROUP[1].$LOWERLIMS / $UPPERLIMS)
- J2 + J3: -80.5 / +205 deg ($PARAM2_GRP[1].$J23LWLIM_DF / $J23UPLIM_DF), which we read as the coupled limits (not yet confirmed by a jog test)
The coupling area was only part of the issue: the joint senses (J3 to J6), the flange frame and the link dimensions were also off. Sergei from your tech team sent a corrected file by email on November 23. Its kinematics match the model we rebuilt, which matches 10 readings of the real controller within 0.14 mm. Its J2/J3 limits come from the M-710iC/45M chart, so the values above may help for the library version.
Thanks to you both.
