Fanuc Program Memory issue ( driver install for fanuc robot )
I don't have enough memory on a FANUC 120iC robot and was thinking would this option be able to run larger programs as it wouldn't be limited to the memory on the controller?
Right now, I have to break programing into multiple files for 3D printing before uploading them into the controller with the upload option.
Thanks,
Andrew
You can use the Fanuc Dripfeed postprocessor
This will Generate a drip feeder program that will split long programs in subprograms and load them to the controller as they are executed
The dripfeed post-processor will create a Python file, most likely in "C:\Users\xxx\Documents\RoboDK".
You can then run this .py file to start the dripfeed.
Prior to generating the program, you also need to properly set the controller IP address in RoboDK.
1. Right-click a robot
2. Select "Connect to robot…"
3. Enter the IP of the robot
You also need to make sure the FTP server is properly set on the controller side:
https://robodk.com/doc/en/Robots-Fanuc.html#FTP-Fanuc
