G code is not working on Reis Rl130p Cnc Base Robot
When i try to run G code with multiple commands on  Reis Rl130p Cnc Base Robot
for example( G91
G1 X1 Y2 Z1.0
G1 X3.5 Y5.0 Z1.0)
it doesnt work it tells can't find a start point when i run a single command G1 X1 Y2 Z1.0 it actually works  what should i do to program a robot with g code is there any tutorial any example for this  or what i should do with this error?
Could you please send us a guideline for G-Code? Thank you.
We have 3 post processors that allow you to generate G-code. You may need to customize the G-code output for your controller.
More information about post processors here:
https://robodk.com/post-processors
A similar question was posted here:
https://robodk.com/forum/Thread-ISO-G-Co...ut-program
3 Guest(s)
