Handling singularities in Real-Time
Hello everyone,
I hope that you are all doing well.
I am currently working on a project involving the use of a Motion Tracker to teleoperate a real mecademic robot in real-time. While the teleoperation is functioning smoothly, I've encountered a challenge when a human operator executes a movement, leading the robot into a singularity configuration and causing it to stop.
Is there a way to implement a strategy through the API to avoid singularities, such as skipping Cartesian positions that result in a singularity. Please note that in this project, long treatment delays are not acceptable due to the real-time nature of the teleoperation.
Thank you in advance.
BEN SAID Aymane
You can check the feasibility of movements using the API by using the functions MoveL_Test and MoveJ_Test.
This example shows how to move through a set of points in a cube by prioritizing linear movements over joint movements:
https://robodk.com/doc/en/PythonAPI/exam...easibility
