How to call "IF else code using program call
Hi, I would like to ask if I want to do an IF/Else condition using the program so for example if My IO_5 is 1 I would like to run "Program A" and if IO_5 is 0, I want to run " program B". just wondering if it's possible.
If I have to use python to run the If Else, how do I call the program Example " Drop slot 4" that I created in Python.
I have attached my FILe inside too.
Hi Timothy,
I don't think that your attachment worked properly.
And to answer your question, yes you need to use Python to implement If/else statements.
EDIT: The latest release of RoboDK lets you use IF and WHILE statements directly from the UI.
Hi Jeremy, sorry I have reattached the file
RE:
Attached Files Image(s)
.rdk   Capstone_V2.6(Add cap area).rdk (Size: 2.37 MB / Downloads: 762)
Hi Timothy,
Did you take a look at the Python API documentation? Here it is: https://robodk.com/doc/en/PythonAPI/intro.html
The API is not my strong point but I'm pretty sure you can do something like:
If RDK.getDI("NameOfTheInput") = True:
  RDK.RunProgram("NameOfTheProgram1")
else:
  RDK.RunProgram("NameOfTheProgram2")
(07-11-2020, 11:36 AM)Timothychew Wrote: Hi Jeremy
Thank you so much!
