How to convert points to Targets
I'm working with the Example 6.6: CSV file to Program (XYZ) for a project.
How do I convert those points to Targets?
Notes: You can select one or move movement instructions and select “Select targets” to see the targets.
I can select multi-points at a time but no way to "Select targets" to see the targets.
Can you share your sample RoboDK project and the CSV file you are trying to load?
.zip   Example-Import-CSV-XYZWPR.zip (Size: 11.28 KB / Downloads: 79)
.rdk   UR10e xyzwpr import.rdk (Size: 3.25 MB / Downloads: 82)
(07-03-2025, 10:00 PM)Albert Wrote: Can you share your sample RoboDK project and the CSV file you are trying to load?
As attached. Thanks
You can import this CSV file by using just File - Open
Once the points have been imported as a single object, the Points Utilities Add-in can be installed and used:
https://robodk.com/addin/com.robodk.app.pointutilities
Select your point object - Utilities - Point utilities - Convert Points To Targets
You can also use Utilities - Point Follow Project just with the imported point object
(07-08-2025, 03:55 PM)Sergei Wrote: You can import this CSV file by using just File - Open
hi Sergei ,
  Carried out Points Utilities as you mentioned. But how do I make the robot move along with those targets?
You can create a program by selecting the targets you want to add and then using the Program - Move Linear Instruction (or Move Joint Instruction) command
(07-08-2025, 04:58 PM)Sergei Wrote: You can create a program by selecting the targets you want to add and then using the Program - Move Linear Instruction (or Move Joint Instruction) command
hi Sergei ,
  I have added reference frame and tool then the robot move along with targets. THANKS!
How do I set those coordinates with CSV file name disappear?
You can adjust visibility settings on the Tools - Options - Display tab. See image attached.
Thanks.
