How to create Box with Python
Hello, I would like to create boxes from a python script of the dimensions that interest me.
I'm testing but I can't create boxes
Example:
from robodk import robolink, robomath
RDK = robolink.Robolink()
width = 100  # Ancho de la caja
length = 200  # Largo de la caja
height = 50  # Alto de la caja
# Crear el box
box = RDK.AddObject('Box', robomath.Mat([width, length, height]))
box.setPose(robomath.Mat([0, 0, 0, 0, 0, 0]))  # Matriz de transformación (pose) en (X, Y, Z, Rx, Ry, Rz)
print("Box creado exitosamente en RoboDK.")
Should I use some other function?
Here is an example of how you can create a box.
This script loads a 1*1*1 mm cube from the SLD file and scales it:
from robodk import *
box_x_str = mbox("X = ", entry="100.0")
if not box_x_str:
    quit()
else:
    box_x = float(box_x_str)
box_y_str = mbox("Y = ", entry="100.0")
if not box_y_str:
    quit()
else:
    box_y = float(box_y_str)
box_z_str = mbox("Z = ", entry="100.0")
if not box_z_str:
    quit()
else:
    box_z = float(box_z_str)
path = robodialogs.getOpenFileName(path_preference='C:\\', strfile='', strtitle='Open', defaultextension='.*', filetypes=[('Models Files', '.sld')])
box_item = RDK.AddFile(path)
box_item.setName('Box')
box_item.setPose(robomath.transl(0.0, 0.0, 0.0))
box_item.Scale([box_x, box_y, box_z])
box_item.setColor([0.5, 0.5, 0.5])
box_frame_item = RDK.AddFrame('Box Frame')
box_frame_item.setPose(robomath.transl(0.0, 0.0, 0.0))
box_item.setParent(box_frame_item)
You can find the RoboDK Python API description here:
https://robodk.com/doc/en/PythonAPI/index.html
You can also take a look at the Shape Add-in and the Box Spawner Add-in:
https://robodk.com/addin/com.robodk.app.shape
https://robodk.com/addin/com.robodk.app.boxspawner
.sld   cube.sld (Size: 13.27 KB / Downloads: 450)
